Inleiding
This guide will walk you through the process of replacing the Main Power Receptacle in a Bear 1000 Ventilator. Found on page 89 in the full service manual.
Wat je nodig hebt
Remove the ribbon cable at the connection on the oxygen blender control board.
Note and mark the orientation of the wires. Remove the two wires going to the fuses at the fuse end and the ground wire going to the main ground stud.
Bijna klaar!
Conclusie
