Ga door naar hoofdinhoud
Battery Disconnection
Alleen vereisten
Deze gids is alleen bedoeld voor beginners! Deze gids maakt deel uit van een andere procedure en is niet bedoeld om alleen te worden gebruikt.
Wat je nodig hebt
  1. Battery Disconnection, Apply tape to a cracked screen: stap 1, afbeelding 1 van 3 Battery Disconnection, Apply tape to a cracked screen: stap 1, afbeelding 2 van 3 Battery Disconnection, Apply tape to a cracked screen: stap 1, afbeelding 3 van 3
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  2. Battery Disconnection, Heat the bottom edge: stap 2, afbeelding 1 van 1
    • Completely power off your device before you begin.
    • Apply a heated iOpener to the bottom edge of the device for 90 seconds to loosen the adhesive underneath.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  3. Battery Disconnection, Screen removal information: stap 3, afbeelding 1 van 3 Battery Disconnection, Screen removal information: stap 3, afbeelding 2 van 3 Battery Disconnection, Screen removal information: stap 3, afbeelding 3 van 3
    • While you're waiting for the adhesive to loosen, note the following:
    • The areas at the top and bottom of the screen are sensitive to prying.
    • Don't insert a pick more than 3 mm to avoid damaging the screen.
    • There's a long circuit board attached to the screen that sits parallel to the left edge.
    • Don't insert a pick more than 1.5 mm to avoid damaging the circuit board.
    • The first two images are mirrored for demonstration purposes.
  4. Battery Disconnection, Insert an opening pick: stap 4, afbeelding 1 van 3 Battery Disconnection, Insert an opening pick: stap 4, afbeelding 2 van 3 Battery Disconnection, Insert an opening pick: stap 4, afbeelding 3 van 3
    • Once the screen is warm to touch, apply a suction handle to the bottom edge of the screen and as close to the edge as possible.
    • Lift the screen with the suction handle to create a small gap between the screen and the frame.
    • Insert an opening pick into the gap between the frame and the screen.
    • Don't insert the pick more than 1.5 mm to avoid damaging the circuit board.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  5. Battery Disconnection, Separate the bottom adhesive: stap 5, afbeelding 1 van 3 Battery Disconnection, Separate the bottom adhesive: stap 5, afbeelding 2 van 3 Battery Disconnection, Separate the bottom adhesive: stap 5, afbeelding 3 van 3
    • Slide the pick along the bottom edge of the device towards the bottom-right corner.
    • Leave the pick in to prevent the adhesive from resealing.
  6. Battery Disconnection, Heat the right edge: stap 6, afbeelding 1 van 1
    • Apply a heated iOpener to the right edge of the device for 90 seconds to loosen the adhesive underneath.
  7. Battery Disconnection, Separate the bottom-right corner adhesive: stap 7, afbeelding 1 van 3 Battery Disconnection, Separate the bottom-right corner adhesive: stap 7, afbeelding 2 van 3 Battery Disconnection, Separate the bottom-right corner adhesive: stap 7, afbeelding 3 van 3
    • Rotate the opening pick around the bottom-right corner of the device.
  8. Battery Disconnection, Separate the remaining adhesive: stap 8, afbeelding 1 van 2 Battery Disconnection, Separate the remaining adhesive: stap 8, afbeelding 2 van 2
    • Repeat the heating, slicing, and leaving opening picks for the remaining edges of the device.
    • When you slice near the front camera, don't insert the pick more than 1.5 mm to avoid damaging or smearing the camera.
  9. Battery Disconnection, Reposition the screen: stap 9, afbeelding 1 van 3 Battery Disconnection, Reposition the screen: stap 9, afbeelding 2 van 3 Battery Disconnection, Reposition the screen: stap 9, afbeelding 3 van 3
    • If there's still resistance around the edges of the screen, use an opening pick to cut the adhesive again.
    • Don't try to remove the screen all the way yet; it's still connected to the frame by a flex cable.
    • With the bottom of the device facing you, pull the right edge of the screen up and towards the left edge of the device.
    • Rest the screen upside down and parallel to the frame before continuing.
    • Don't twist the screen or move it too far away from the frame to avoid damaging the flex cable.
  10. Battery Disconnection, Unfasten the display cable bracket: stap 10, afbeelding 1 van 2 Battery Disconnection, Unfasten the display cable bracket: stap 10, afbeelding 2 van 2
    • Use a Phillips #000 screwdriver to remove the five 1.2 mm-long screws securing the frame bracket to the frame.
  11. Battery Disconnection, Remove the display cable bracket: stap 11, afbeelding 1 van 2 Battery Disconnection, Remove the display cable bracket: stap 11, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use tweezers, or your fingers, to remove the display cable bracket from the frame.
  12. Battery Disconnection, Disconnect the display: stap 12, afbeelding 1 van 3 Battery Disconnection, Disconnect the display: stap 12, afbeelding 2 van 3 Battery Disconnection, Disconnect the display: stap 12, afbeelding 3 van 3
    • Use the flat end of a spudger to pry up and disconnect the display cable's two press connectors secured to the frame.
  13. Battery Disconnection, Remove the screen: stap 13, afbeelding 1 van 2 Battery Disconnection, Remove the screen: stap 13, afbeelding 2 van 2
    • Remove the screen from the frame.
  14. Battery Disconnection, Disconnect the battery: stap 14, afbeelding 1 van 2 Battery Disconnection, Disconnect the battery: stap 14, afbeelding 2 van 2
    • The the flat end of a spudger to pry up and disconnect the battery's press connector secured to the frame.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
Conclusie
Alex Diaz-Kokaisl
226.763 Reputatie
1.106 handleidingen geschreven
iFixit Lid van iFixit
Staff
124 Leden
24.271 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 100
