Ga door naar hoofdinhoud
Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta"
Wat je nodig hebt
  1. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta", Knobs: stap 1, afbeelding 1 van 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta", Knobs: stap 1, afbeelding 2 van 2
    • Underneath the sink there are two valves that supply water to each knob. Turn off the supply by twisting the valves tightly to the right.
    • The water supply needs to be off before starting the replacement. Failure to do so can result in water spouting all over the area, causing damage.
  2. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 2, afbeelding 1 van 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 2, afbeelding 2 van 2
    • Double-check that the water supply is off by twisting the faucet knobs to the left.
  3. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 3, afbeelding 1 van 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 3, afbeelding 2 van 2
    • With the 1/8” flathead screwdriver, insert through the groove on the edge of the hot-n-cold caps, loosen, and remove them.
  4. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 4, afbeelding 1 van 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 4, afbeelding 2 van 2
    • Using the PZ1 starhead screwdriver, loosen the 19.1 mm oval head screw.
  5. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 5, afbeelding 1 van 3 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 5, afbeelding 2 van 3 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 5, afbeelding 3 van 3
    • Remove the 19.1 mm oval head screw by pulling it up from the knob.
    • Lift the knob from the faucet to remove it.
  6. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 6, afbeelding 1 van 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 6, afbeelding 2 van 2
    • Use an adjustable wrench to loosen the bonnet nut.
  7. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 7, afbeelding 1 van 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 7, afbeelding 2 van 2
    • Remove the bonnet nut from the faucet.
  8. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 8, afbeelding 1 van 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 8, afbeelding 2 van 2
    • Remove the escutcheon by pulling it out from the valve.
  9. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 9, afbeelding 1 van 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 9, afbeelding 2 van 2
    • Place the new escutcheon by pushing it down into the valve.
  10. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 10, afbeelding 1 van 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 10, afbeelding 2 van 2
    • Install the new bonnet nut by placing it over and around the escutcheon.
  11. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 11, afbeelding 1 van 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 11, afbeelding 2 van 2
    • Using an adjustable wrench, tighten the bonnet nut by twisting it to the right.
  12. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 12, afbeelding 1 van 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 12, afbeelding 2 van 2
    • Install the new knob by placing it on top and around the escutcheon and bonnet nut.
  13. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 13, afbeelding 1 van 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 13, afbeelding 2 van 2
    • Insert the 19.1 mm oval head screw into the top of the knob.
  14. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 14, afbeelding 1 van 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 14, afbeelding 2 van 2
    • Using the PZ1 starhead screwdriver, tighten the screw by twisting it to the right.
  15. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 15, afbeelding 1 van 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 15, afbeelding 2 van 2
    • Install the new hot-n-cold caps by snapping them onto the top of the knobs.
  16. Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 16, afbeelding 1 van 2 Bathroom Sink Knob Replacement with the "Danco Faucet Remodeling Kit for Delta": stap 16, afbeelding 2 van 2
    • Turn on the water supply by twisting the valves to the left.
Conclusie
Test that the replacement was done correctly and that the water supply is on by twisting the faucet knobs to the right. Enjoy your new remodeled faucet!
Één andere persoon heeft deze handleiding voltooid.
Benjamin Figueroa
295 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 146
