Ga door naar hoofdinhoud
Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement
Wat je nodig hebt
  1. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Disconnect the spark plug wire: stap 1, afbeelding 1 van 2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Disconnect the spark plug wire: stap 1, afbeelding 2 van 2
    • Before you begin, ensure that the engine is powered down and cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire and pull firmly to disconnect it.
  2. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Flip the engine switch to the off position: stap 2, afbeelding 1 van 2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Flip the engine switch to the off position: stap 2, afbeelding 2 van 2
    • Flip the red engine ON/OFF switch to the OFF position.
  3. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Close the fuel valve: stap 3, afbeelding 1 van 2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Close the fuel valve: stap 3, afbeelding 2 van 2
    • Flip the fuel valve lever to the OFF position.
  4. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Turn off the ignition: stap 4, afbeelding 1 van 2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Turn off the ignition: stap 4, afbeelding 2 van 2
    • Flip the ignition switch to the OFF position.
    • Ensure the wheel drive control lever is set to the neutral position.
  5. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Allow the wheels to freewheel: stap 5, afbeelding 1 van 3 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Allow the wheels to freewheel: stap 5, afbeelding 2 van 3 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Allow the wheels to freewheel: stap 5, afbeelding 3 van 3
    • Pull the locking pin out and rotate it 90˚ to unlock the right wheel from the hub.
    • Repeat for the left wheel.
  6. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Add wheel chocks: stap 6, afbeelding 1 van 1
    • Insert wheel chocks underneath each wheel to keep the device stationary during disassembly.
  7. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the grease fitting: stap 7, afbeelding 1 van 1
    • Use an 8 mm socket to remove the outboard bearing grease fitting.
  8. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the side plate bolts: stap 8, afbeelding 1 van 2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the side plate bolts: stap 8, afbeelding 2 van 2
    • Use a 9/16 inch socket to remove the four bolts securing the tine shaft to the side plate.
    • Use a 9/16 socket and wrench to remove the five bolts and accompanying nuts securing the side plate to the frame, three on the outside and two in the wheel well.
  9. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Tilt the tiller: stap 9, afbeelding 1 van 2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Tilt the tiller: stap 9, afbeelding 2 van 2
    • Tilt the tiller up so the motor side is resting on the work surface with the tines raised.
  10. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the tine cover bolts: stap 10, afbeelding 1 van 1
    • Use a 1/2 inch socket and wrench to remove the four bolts and accompanying nuts securing the side plate to the tine cover.
  11. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the side plate: stap 11, afbeelding 1 van 3 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the side plate: stap 11, afbeelding 2 van 3 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the side plate: stap 11, afbeelding 3 van 3
    • Slide the side plate down and away from the device to remove it.
  12. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Clean the assembly: stap 12, afbeelding 1 van 2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Clean the assembly: stap 12, afbeelding 2 van 2
    • Use a clean paper towel or shop rag to remove the grease from the outboard bearing assembly.
  13. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the outboard bearing assembly bolt: stap 13, afbeelding 1 van 1
    • Use a 9/16 inch socket to remove the bolt securing the outboard bearing assembly to the tine shaft.
  14. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the washers: stap 14, afbeelding 1 van 1
    • Remove the three washers, held in place by the bolt, from the outboard bearing assembly.
  15. Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the outboard bearing assembly: stap 15, afbeelding 1 van 2 Barreto Tillers E1320HTRLR 2016 Outboard Bearing Assembly Replacement, Remove the outboard bearing assembly: stap 15, afbeelding 2 van 2
    • Pull the assembly off of the tine shaft to remove it.
Conclusie
Carsten Frauenheim
104.484 Reputatie
338 handleidingen geschreven
iFixit Lid van iFixit
Community
142 Leden
16.238 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 11
Altijd: 212
