Ga door naar hoofdinhoud
Barbie Doll Hair Replacement
Wat je nodig hebt
  1. Barbie Doll Hair Replacement, Barbie Doll Hair: stap 1, afbeelding 1 van 3 Barbie Doll Hair Replacement, Barbie Doll Hair: stap 1, afbeelding 2 van 3 Barbie Doll Hair Replacement, Barbie Doll Hair: stap 1, afbeelding 3 van 3
    • Use light force to pull barbie head off of the body.
    • If stuck, soak in warm water to loosen.
  2. Barbie Doll Hair Replacement: stap 2, afbeelding 1 van 2 Barbie Doll Hair Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Cut off all of the remaining hair using scissors.
    • Tweezers may be used once hair is too short for scissors.
    • It is important to remove as much hair as possible.
  3. Barbie Doll Hair Replacement: stap 3, afbeelding 1 van 3 Barbie Doll Hair Replacement: stap 3, afbeelding 2 van 3 Barbie Doll Hair Replacement: stap 3, afbeelding 3 van 3
    • Cut the yarn pieces for doll hair.
    • With a ruler, measure equal pieces twice as long as intended hair length.
    • Cut enough for desired hair thickness.
    • To make up for inconsistencies in length, you may cut pieces longer and trim later.
  4. Barbie Doll Hair Replacement: stap 4, afbeelding 1 van 3 Barbie Doll Hair Replacement: stap 4, afbeelding 2 van 3 Barbie Doll Hair Replacement: stap 4, afbeelding 3 van 3
    • Thread yarn between the forked tip of the reroot tool.
    • Attempt to thread the yarn at its midpoint for more even hair.
    • Insert the reroot tool into a small hole atop the doll's head.
    • Push the yarn inside as far as the tool will allow.
    • Remove the reroot tool from the head, leaving the yarn tucked inside.
  5. Barbie Doll Hair Replacement: stap 5, afbeelding 1 van 1
    • Add glue to the inside of the doll's head.
    • Plug in and preheat the glue gun.
    • Insert glue gun from the base of the head.
    • Add a thicker layer of glue for stronger hair.
    • Hot glue can cause burns when exposed directly to skin.
  6. Barbie Doll Hair Replacement: stap 6, afbeelding 1 van 1
    • After applying glue, use the blunt end of the rerooting tool to spread glue to cover the inside of the head.
    • Do this immediately after applying glue, because it will dry quickly.
  7. Barbie Doll Hair Replacement: stap 7, afbeelding 1 van 2 Barbie Doll Hair Replacement: stap 7, afbeelding 2 van 2
    • Wait for the glue to dry (15-30 minutes).
    • Once the glue is dry, attach the Barbie head back onto the neck joint.
    • For extra styling and volume, you may separate yarn strands.
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Miranda Comstock
170 Reputatie
1 Handleiding geschreven
UC Davis, Team 2-3, Andersen Winter 2023 Lid van UC Davis, Team 2-3, Andersen Winter 2023
UCD-ANDERSEN-W23S2G3
3 Leden
2 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 22
Afgelopen 30 dagen: 96
Altijd: 1,813
