Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Squeeze the brake arms together and lift the brake cable from the caliper arms.
Hold the wheel to the ground, and pull the bike frame up and away to remove the wheel from the bike.
Unscrew the quick release nut from the quick release axle. Remove the quick release axle.
After removing the axle you should notice that there are two springs on it. Be careful not to lose these.
Fit the cone wrench to the cone, and fit the open end wrench to the top lock nut. Hold the cone in place with the cone wrench and turn the open end wrench to loosen and remove the top lock nut.
Inspect cone surfaces and all ball bearings for dents, cracks or blemishes.
If any are damaged, replace them.
Clean bearings, the bearing races, and cones by wiping them off with a rag.
Liberally apply grease to the bearings, races, and cones.
Insert the axle back into the wheel, with the still attached nut and cone on the bottom side of the wheel.
Carefully drop the axle out from the bottom of the wheel.
Re-insert the axle from the top side of the wheel, so that the attached nut and bearing and cone set are now sticking out of the top.
Now flip the wheel upside down.
Insert the remaining 10 bearings into the bearing races on the opposite side.
Hand tighten bearing cone onto the free end of the axle, so that it touches the bearings without putting any pressure on them.
Slide the washer onto the axle.
Hand tighten the lock nut against the cone and washer.
Once in proper position, use the cone wrench and open wrench to tighten the lock nut.
Check the way that the axle spins in the wheel. The action should be smooth, with virtually no slop when wiggled. If it is to tight or too sloppy then you need to repeat the previous step.
Reinsert the quick release axle, and put the wheel back on the bike.
The springs should have the smaller tapered end closest to the hub
3 andere personen hebben deze handleiding voltooid.
Één opmerking
Display and text were really helpful. I was wondering what happened to the sprocket assembly. from steps 1 through 3. This worked fine for the front wheel when I did it, but I'm not sure about working on the rear wheel. Does the sprocket assembly stay on the axle when you take off the lock nut and cone from the other side? Thanks Bob
