Ga door naar hoofdinhoud
Back Panel Removal
Wat je nodig hebt
  1. Back Panel Removal, Battery: stap 1, afbeelding 1 van 1
    • Power down the computer and unplug the power adapter.
  2. Back Panel Removal: stap 2, afbeelding 1 van 1
    • Flip the laptop upside down. Locate the two latches on both sides of the battery.
  3. Back Panel Removal: stap 3, afbeelding 1 van 3 Back Panel Removal: stap 3, afbeelding 2 van 3 Back Panel Removal: stap 3, afbeelding 3 van 3
    • Slide the latch on the right outwards, releasing the lock. The latch stays unlocked once moved.
    • Simultaneously slide the latch on the left outwards while pulling the battery towards you.
    • Do not touch the metal connectors on the laptop and the battery.
  4. Back Panel Removal, Back Panel Removal: stap 4, afbeelding 1 van 1
    • Remove the single captive screw on the back panel with your Phillips #1 screwdriver.
  5. Back Panel Removal: stap 5, afbeelding 1 van 2 Back Panel Removal: stap 5, afbeelding 2 van 2
    • Pry the removal tab up. You will feel and hear the first clip release, popping up slightly.
    • Work your way around the border of the panel, releasing the rest of the clips.
    • Once all clips are released, lift the cover up and pull towards you.
Conclusie
To replace the back panel, follow the steps in reverse.
Austin Bons
1.131 Reputatie
8 handleidingen geschreven
UC Davis, Team 2-2, Oliver Fall 2016 Lid van UC Davis, Team 2-2, Oliver Fall 2016
UCD-OLIVER-F16S2G2
5 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 16
Afgelopen 30 dagen: 89
Altijd: 8,102
