Ga door naar hoofdinhoud
Baby Einstein Take Along Tunes Battery Socket Replacement
Wat je nodig hebt
  1. Baby Einstein Take Along Tunes Battery Socket Replacement, Battery Socket: stap 1, afbeelding 1 van 1
    • Set the device on it's face with the back facing up.
  2. Baby Einstein Take Along Tunes Battery Socket Replacement: stap 2, afbeelding 1 van 1
    • Begin by removing all highlighted screws with a using a Phillips #1 Screwdriver.
  3. Baby Einstein Take Along Tunes Battery Socket Replacement: stap 3, afbeelding 1 van 1
    • Remove the battery plate with a plastic opening tool and set it aside.
  4. Baby Einstein Take Along Tunes Battery Socket Replacement: stap 4, afbeelding 1 van 1
    • Remove each battery with a plastic opening tool and set them aside.
  5. Baby Einstein Take Along Tunes Battery Socket Replacement: stap 5, afbeelding 1 van 1
    • Separate the device in two parts by using the plastic opening tool.
  6. Baby Einstein Take Along Tunes Battery Socket Replacement: stap 6, afbeelding 1 van 1
    • Remove the top piece and place it aside, keeping the bottom half with the mechanics.
  7. Baby Einstein Take Along Tunes Battery Socket Replacement: stap 7, afbeelding 1 van 1
    • Remove the highlighted screws using a Phillips #1 Screwdriver.
  8. Baby Einstein Take Along Tunes Battery Socket Replacement: stap 8, afbeelding 1 van 1
    • Use the plastic opening tool and carefully set the LED panel to the side, exposing the wires underneath.
  9. Baby Einstein Take Along Tunes Battery Socket Replacement: stap 9, afbeelding 1 van 1
    • With the precision tweezers, straighten the metal connectors to remove the terminals from the other side.
  10. Baby Einstein Take Along Tunes Battery Socket Replacement: stap 10, afbeelding 1 van 2 Baby Einstein Take Along Tunes Battery Socket Replacement: stap 10, afbeelding 2 van 2
    • Sever the red wire from the metal connector with the precision tweezers.
  11. Baby Einstein Take Along Tunes Battery Socket Replacement: stap 11, afbeelding 1 van 2 Baby Einstein Take Along Tunes Battery Socket Replacement: stap 11, afbeelding 2 van 2
    • Sever the black wire from the metal connector with the precision tweezers.
  12. Baby Einstein Take Along Tunes Battery Socket Replacement: stap 12, afbeelding 1 van 2 Baby Einstein Take Along Tunes Battery Socket Replacement: stap 12, afbeelding 2 van 2
    • Flip the device on its face and remove the battery terminals with a metal spudger.
Conclusie
Shreya Sunny
607 Reputatie
6 handleidingen geschreven
USF Tampa, Team 2-2, Sullivan Fall 2015 Lid van USF Tampa, Team 2-2, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G2
4 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 562
