Inleiding
Using a hex 2.0 driver, you will remove the top cover. using a pair of tweezers, you will then be able to remove and replace the Brck Motherboard.
Wat je nodig hebt
Remove the nut and washer from the RF connector, located where the antenna was connected.
Bijna klaar!
Conclusie
