Ga door naar hoofdinhoud
BRCK v1 Battery Replacement
Wat je nodig hebt
  1. BRCK v1 Battery Replacement, Antenna: stap 1, afbeelding 1 van 1
    • Stand the device on its side so the antenna is sitting on the top.
  2. BRCK v1 Battery Replacement: stap 2, afbeelding 1 van 2 BRCK v1 Battery Replacement: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use the tweezers to grip the neck of the antenna(the part closest to the device).
    • Use opposite hand to twist off the body of the antenna.
  3. BRCK v1 Battery Replacement, Top Cover: stap 3, afbeelding 1 van 1
    • Place the face of the device showing BRCK face up.
  4. BRCK v1 Battery Replacement: stap 4, afbeelding 1 van 1
    • Remove the four screws(4mm hex head) on the corners of the device with a Hex 2.0 Screwdriver.
  5. BRCK v1 Battery Replacement: stap 5, afbeelding 1 van 1
    • Remove the top cover.
  6. BRCK v1 Battery Replacement, Motherboard: stap 6, afbeelding 1 van 2 BRCK v1 Battery Replacement, Motherboard: stap 6, afbeelding 2 van 2
    • Remove the nut and washer from the RF connector, located where the antenna was connected.
  7. BRCK v1 Battery Replacement: stap 7, afbeelding 1 van 2 BRCK v1 Battery Replacement: stap 7, afbeelding 2 van 2
    • Unplug the red, black, and yellow wire connection by lifting up.
  8. BRCK v1 Battery Replacement: stap 8, afbeelding 1 van 3 BRCK v1 Battery Replacement: stap 8, afbeelding 2 van 3 BRCK v1 Battery Replacement: stap 8, afbeelding 3 van 3
    Koop
    • Carefully insert tweezers under the black tab, and lift to release the clip.
    • Slide the ribbon out from under the clip to free the motherboard.
  9. BRCK v1 Battery Replacement: stap 9, afbeelding 1 van 1
    • Remove outside rubber covers by lifting them out of place.
  10. BRCK v1 Battery Replacement: stap 10, afbeelding 1 van 3 BRCK v1 Battery Replacement: stap 10, afbeelding 2 van 3 BRCK v1 Battery Replacement: stap 10, afbeelding 3 van 3
    • Slowly lift the motherboard out from the device by lifting it from the end next to the ribbon connection.
    • Lift and pull out of place.
  11. BRCK v1 Battery Replacement, Battery: stap 11, afbeelding 1 van 3 BRCK v1 Battery Replacement, Battery: stap 11, afbeelding 2 van 3 BRCK v1 Battery Replacement, Battery: stap 11, afbeelding 3 van 3
    • Flip device upside down. Hold the device and tap into your other hand with varying force to remove battery.
    • This may take a few tries to remove the battery.
Conclusie
Jeret Buerger
501 Reputatie
5 handleidingen geschreven
Cal Poly, Team 12-3, Lancaster Spring 2015 Lid van Cal Poly, Team 12-3, Lancaster Spring 2015
CPSU-LANCASTER-S15S12G3
3 Leden
14 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 216
