Inleiding
The display should be replaced in the event that it gets damaged beyond reasonable repair. Removing the display requires some caution due to the fragile nature of the ribbon connector.
Wat je nodig hebt
Remove the four 15.5 mm PH2 screws securing the base plate to the device.
Remove the three 15.5mm PH2 screws holding the front-mesh grille in place.
