Inleiding
Did you know that you don't have to stick with the basic BMW kidney grille? You can give your BMW a whole new, high quality M-colored LED kidney grille to pay tribute to the iconic stripes. This LED grille kit is compatible with E46, E36, E60, E64, E65, E90, E92, F10, F30, F25, F32, etc.
Gereedschap
Geen gereedschap nodig.
Onderdelen
  1. You will need to remove a couple of bolts on the front bumper before you can start removing the BMW factory kidney grille.
    • You will need to remove a couple of bolts on the front bumper before you can start removing the BMW factory kidney grille.
  2. When you have enough clearance space, you can wedge your hand in between the gap to pop out the stock kidney grille. Keep maneuvering your hand in the space to ease the stock grille out. Keep maneuvering your hand in the space to ease the stock grille out.
    • When you have enough clearance space, you can wedge your hand in between the gap to pop out the stock kidney grille.
    • Keep maneuvering your hand in the space to ease the stock grille out.
  3. Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
    Doorblader onze winkel
  4. Detach the stock kidney grille from the clips holding it onto the BMW front bumper.
    • Detach the stock kidney grille from the clips holding it onto the BMW front bumper.
  5. Pull out the factory kidney grille. Pull out the factory kidney grille.
    • Pull out the factory kidney grille.
  6. Use your hand to apply a bit of pressure to pop the new LED M-stripe kidney grille in place Secure the new LED grille onto the clips.
    • Use your hand to apply a bit of pressure to pop the new LED M-stripe kidney grille in place
    • Secure the new LED grille onto the clips.
    • Note: the M-Colored LED stripe is only on the right grille assembly.
    • Tap the wire to the ACC or other 12V power source.
    • Repeat on the other side.
  7. Put the bolts back into the BMW front bumper.
    • Put the bolts back into the BMW front bumper.
    • Enjoy your new M-Colored BMW LED Illuminated kidney grille.
Conclusie
You can see that you didn't need to be an advanced car installer to attempt this. This makes the installation great for beginners as well as seasoned car fans alike.
Eric Wu
2.522 Reputatie
23 handleidingen geschreven
Één commentaar
I have been reading your posts regularly. I need to say that you are doing a fantastic job. Please keep up the great work.
Photoshop error 16
Johnson Berry - Antwoord
Weergavestatistieken:
Afgelopen 24 Uren: 4
Afgelopen 7 Dagen: 32
Afgelopen 30 Dagen: 115
Altijd: 6,109
