Ga door naar hoofdinhoud
BLU WIN HD LTE Battery Replacement
Wat je nodig hebt
  1. BLU WIN HD LTE Battery Replacement, Back Case: stap 1, afbeelding 1 van 1
    • Pry the back cover from the bottom of the phone, pulling outwards and upwards.
  2. BLU WIN HD LTE Battery Replacement: stap 2, afbeelding 1 van 1
    • Fully remove the cover and set aside in a safe place.
  3. BLU WIN HD LTE Battery Replacement, Frame Cover: stap 3, afbeelding 1 van 1
    • Remove all the nine 2mm screws using the JIS #00 Screwdriver.
  4. BLU WIN HD LTE Battery Replacement: stap 4, afbeelding 1 van 1
    • Pry the frame off using the spudger pulling upwards going to different areas around the device.
    • The back cover is secured by glue. Removal could be more difficult than expected.
  5. BLU WIN HD LTE Battery Replacement, Battery: stap 5, afbeelding 1 van 2 BLU WIN HD LTE Battery Replacement, Battery: stap 5, afbeelding 2 van 2
    • Remove the battery out using the black nylon spudger.
    • Battery is secured by glue so use more force to take it out.
Conclusie
2 opmerkingen
I replaced the battery but now there is a symbol on the screen, box with a question mark, what does that mean?
raybrooks - Antwoord
I hope someone else has had this issue an has a solution. Thank you in advance for any and all help.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 640
