Inleiding
Use this guide to replace muffled speaker/ sound issues.
Complete the prerequisite before starting.
For better sound make sure volume settings are turned to desired loudness.
Use this guide to also check for water damage before replacement.
Wat je nodig hebt
Completely remove SIM card port from side of phone using the SIM Card Eject Tool.
Release the back cover (it may be glued down encasing the phone) using the suction device to lift the back off.
Begin inserting the pick sliding it between the back of the phone and the cover to completely remove back cover, if suction does not lift.
Slide the spudger between the speaker covers (might be held down with adhesive stickiness.)
Use the PH000 screwdriver to remove any leftover screws near bottom of the device.
3 andere personen hebben deze handleiding voltooid.
