Ga door naar hoofdinhoud
BLU Vivo 5 Mini Back Cover Replacement
Wat je nodig hebt
  1. BLU Vivo 5 Mini Back Cover Replacement, Back Cover: stap 1, afbeelding 1 van 3 BLU Vivo 5 Mini Back Cover Replacement, Back Cover: stap 1, afbeelding 2 van 3 BLU Vivo 5 Mini Back Cover Replacement, Back Cover: stap 1, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Remove the 2 screws along the bottom on either side of the speaker port with the size 2 Pentalobe driver.
    • After screws are removed, dislodge the speaker and charger port cover from device using the tweezers.
  2. BLU Vivo 5 Mini Back Cover Replacement: stap 2, afbeelding 1 van 3 BLU Vivo 5 Mini Back Cover Replacement: stap 2, afbeelding 2 van 3 BLU Vivo 5 Mini Back Cover Replacement: stap 2, afbeelding 3 van 3
    • Remove the top and bottom covers.
    • Start by sliding the pick around the edges of both covers. (If you have the glue adhesive removal tool use that instead of pick, as it creates less damage.)
    • After freeing the edges gentle start peeling the covers off.
  3. BLU Vivo 5 Mini Back Cover Replacement: stap 3, afbeelding 1 van 3 BLU Vivo 5 Mini Back Cover Replacement: stap 3, afbeelding 2 van 3 BLU Vivo 5 Mini Back Cover Replacement: stap 3, afbeelding 3 van 3
    • Using a Phillips #000, remove all 10 screws found on the back of the phone.
    • The 6 on the bottom are to be removed with a size PH000 Phillips Head screwdriver.
    • The 4 on the top can be removed with the same screwdriver.
  4. BLU Vivo 5 Mini Back Cover Replacement: stap 4, afbeelding 1 van 3 BLU Vivo 5 Mini Back Cover Replacement: stap 4, afbeelding 2 van 3 BLU Vivo 5 Mini Back Cover Replacement: stap 4, afbeelding 3 van 3
    • Completely remove SIM card port from side of phone using the SIM Card Eject Tool.
    • Release the back cover (it may be glued down encasing the phone) using the suction device to lift the back off.
    • Begin inserting the pick sliding it between the back of the phone and the cover to completely remove back cover, if suction does not lift.
Conclusie
You can also use steps 1-4 for any other internal replacement.
Één andere persoon heeft deze handleiding voltooid.
Kymari
725 Reputatie
5 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 440
