Ga door naar hoofdinhoud
Inleiding
Replacement guide for the BLU Vivo 5's battery
Technical information:
https://www.gsmarena.com/blu_vivo_5-7857...
  1. Remove the P2 screws. Remove the SIM and SD cards, as well as the adapter.
    • Remove the P2 screws.
    • Remove the SIM and SD cards, as well as the adapter.
  2. Pull off the protective cover from the camera. Remove the screws with a #00 Phillips screwdriver. Remove the screws with a #00 Phillips screwdriver.
    • Pull off the protective cover from the camera.
    • Remove the screws with a #00 Phillips screwdriver.
  3. To remove the bottom cover, pull it upward. To remove the bottom cover, pull it upward. To remove the bottom cover, pull it upward.
    • To remove the bottom cover, pull it upward.
  4. Use a spudger to carefully apply pressure to the indicated areas to remove the cover. Remove the microphone/speaker board assembly by pulling downward. Remove the microphone/speaker board assembly by pulling downward.
    • Use a spudger to carefully apply pressure to the indicated areas to remove the cover.
    • Remove the microphone/speaker board assembly by pulling downward.
  5. The battery has a small notch to facilitate removal, but the battery has been glued in place. To gently remove the battery, pry under it with a thin tool and slide from one side to the other slowly, listening for the sound of the battery coming loose. To gently remove the battery, pry under it with a thin tool and slide from one side to the other slowly, listening for the sound of the battery coming loose.
    • The battery has a small notch to facilitate removal, but the battery has been glued in place.
    • To gently remove the battery, pry under it with a thin tool and slide from one side to the other slowly, listening for the sound of the battery coming loose.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Met dank aan deze vertalers:
es en
80%
Deze vertalers helpen ons de wereld te repareren! Wil je bijdragen?
Begin met vertalen ›
Eneider Colina
2.297 Reputatie
9 handleidingen geschreven
Één commentaar
Umm not sure what BLU Vivo 5 your giving these instructions for, my BLU Vivo 5 has no screws. Looks the same except for bottom speaker area, mine has type c and other wither side 2 slots one for mic one for speaker, no screws.
V'Ger_iTech - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 88
Altijd: 2,508
