Ga door naar hoofdinhoud
BLU Tank II Front Panel Replacement
Wat je nodig hebt
  1. BLU Tank II Front Panel Replacement, Back Panel: stap 1, afbeelding 1 van 2 BLU Tank II Front Panel Replacement, Back Panel: stap 1, afbeelding 2 van 2
    • With the screen facing you, find the left corner of the phone. There should be a visible groove.
    • With your fingers, carefully press a fingernail into the slot and separate the back panel from the phone.
  2. BLU Tank II Front Panel Replacement, Battery: stap 2, afbeelding 1 van 1
    • After the back panel has been removed, put your finger on and press down on the bottom part of the battery.
    • Lift the battery up and carefully remove the battery.
  3. BLU Tank II Front Panel Replacement, Front Panel: stap 3, afbeelding 1 van 2 BLU Tank II Front Panel Replacement, Front Panel: stap 3, afbeelding 2 van 2
    • Using the phillips head screwdriver, remove all 5 2.5mm screws.
  4. BLU Tank II Front Panel Replacement: stap 4, afbeelding 1 van 1
    • Wedge the blue plastic iFixit opening tool between the front plate and the outer lens plate.
    • Carefully separate the front plate from all sides of the phone.
Conclusie
David Kelchner
632 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 5
Altijd: 217
