Inleiding
The motherboard of the BLU Studio G also contains the headphone jack, antenna, and charging port. If any of these components were to break, you may need to do a full motherboard replacement to fix the problem.
Wat je nodig hebt
Stap 1 Motherboard Prerequisite
Voorzichtig: stappen 1-8 komen van een handleiding die in bewerking is.
To remove the back cover, turn the device over, locate the safety indented notch on the bottom left corner as the screen is facing down.
Using your finger (or spudger), prop upwards to detach the back cover properly from the rest of the device.
Locate the two connector clamps on the motherboard.
Carefully place the tip of a precision tweezer or metal spudger under the short light brown plastic clamp. This will release the connectors.
Gently pull out the connectors from the clamp inserts by pulling slowly away from of device using precision tweezers.
