Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Locate the seam between the black and silver pieces of the phone.
Insert a plastic opening tool into the seam and firmly pry the black back piece away from the silver front piece.
Work your way around the edge of phone, firmly prying the pieces apart.
The camera is located in the top left of the frame (if the screen is on the table and the top of the phone is farthest from you).
To remove it, grip the lens itself (the black part) with a pair of precision tweezers and lift straight up.
Één andere persoon heeft deze handleiding voltooid.
