Ga door naar hoofdinhoud
BLU Studio 7.0 II Rear Camera Replacement
Wat je nodig hebt
  1. BLU Studio 7.0 II Rear Camera Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Locate the seam between the black and silver pieces of the phone.
    • Insert a plastic opening tool into the seam and firmly pry the black back piece away from the silver front piece.
    • To create the initial separation for the plastic opening tool, you may need to use either a spudger or metal spudger. If you use a metal spudger, be aware this can damage your phone if you aren't careful.
  2. BLU Studio 7.0 II Rear Camera Replacement: stap 2, afbeelding 1 van 1
    • Work your way around the edge of phone, firmly prying the pieces apart.
  3. BLU Studio 7.0 II Rear Camera Replacement: stap 3, afbeelding 1 van 2 BLU Studio 7.0 II Rear Camera Replacement: stap 3, afbeelding 2 van 2
    • Once the back has been removed, you can snap the new one into place by pressing firmly around the edges with your fingers.
  4. BLU Studio 7.0 II Rear Camera Replacement, Rear Camera: stap 4, afbeelding 1 van 2 BLU Studio 7.0 II Rear Camera Replacement, Rear Camera: stap 4, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • The camera is located in the top left of the frame (if the screen is on the table and the top of the phone is farthest from you).
    • To remove it, grip the lens itself (the black part) with a pair of precision tweezers and lift straight up.
    • The camera is connected to the motherboard with a simple clip connection. This will release as you pull.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Abby
852 Reputatie
5 handleidingen geschreven
Metro State, Team 1-2, Carpenter SU 2016 Lid van Metro State, Team 1-2, Carpenter SU 2016
MSU-CARPENTER-SU16S1G2
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 390
