Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Locate the seam between the black and silver pieces of the phone.
Insert a plastic opening tool into the seam and firmly pry the black back piece away from the silver front piece.
Work your way around the edge of phone, firmly prying the pieces apart.
Using the PH00 screw driver, remove the two 3mm screws.
Remove the metal clip that connects the battery ribbon to the motherboard by lifting up. Precision tweezers work best for this part.
Disconnect the battery connector using a plastic opening tool or the flat end of a spudger.
Using the black spudger, carefully but firmly pry the battery out of the housing.
Één andere persoon heeft deze handleiding voltooid.
