Ga door naar hoofdinhoud
BLU Studio 5.5 Motherboard Replacement
Wat je nodig hebt
  1. BLU Studio 5.5 Motherboard Replacement, Battery: stap 1, afbeelding 1 van 3 BLU Studio 5.5 Motherboard Replacement, Battery: stap 1, afbeelding 2 van 3 BLU Studio 5.5 Motherboard Replacement, Battery: stap 1, afbeelding 3 van 3
    • Locate the notch to remove the back panel at the lower left corner of the panel.
    • Insert the plastic opening tool or a fingernail into the notch.
    • Apply force upwards until back panel becomes loosened.
  2. BLU Studio 5.5 Motherboard Replacement: stap 2, afbeelding 1 van 2 BLU Studio 5.5 Motherboard Replacement: stap 2, afbeelding 2 van 2
    • Remove the loosened back panel and set aside.
    • Locate the notch to remove the battery.
  3. BLU Studio 5.5 Motherboard Replacement: stap 3, afbeelding 1 van 3 BLU Studio 5.5 Motherboard Replacement: stap 3, afbeelding 2 van 3 BLU Studio 5.5 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Insert a plastic opening tool or your fingernail into the notch and apply force upwards until the battery is loosened.
    • Remove the battery and set aside.
  4. BLU Studio 5.5 Motherboard Replacement, Back Panel Assembly: stap 4, afbeelding 1 van 2 BLU Studio 5.5 Motherboard Replacement, Back Panel Assembly: stap 4, afbeelding 2 van 2
    • Locate all twelve screws along the back panel:
    • Seven 5mm screws.
    • Five 3.5mm screws.
    • Using a Phillips #000 screwdriver, remove all twelve screws.
  5. BLU Studio 5.5 Motherboard Replacement: stap 5, afbeelding 1 van 3 BLU Studio 5.5 Motherboard Replacement: stap 5, afbeelding 2 van 3 BLU Studio 5.5 Motherboard Replacement: stap 5, afbeelding 3 van 3
    • Now that all the screws have been removed, use a plastic opening tool to carefully pry at each of the corners until loosened.
    • Be extra careful when prying open as it may damage or snap the thin sides of the panel.
    • Place the plastic opening tool inside the loosened panel and gently push upwards and move along the phone to remove the back panel.
    • Remove the panel as if you were turning the page of a book.
  6. BLU Studio 5.5 Motherboard Replacement, Motherboard: stap 6, afbeelding 1 van 3 BLU Studio 5.5 Motherboard Replacement, Motherboard: stap 6, afbeelding 2 van 3 BLU Studio 5.5 Motherboard Replacement, Motherboard: stap 6, afbeelding 3 van 3
    • Locate the motherboard that is above where the battery was removed.
    • Remove the three screws holding down the motherboard to the phone.
    • Locate all 7 flex cable connectors that are attached to the motherboard.
  7. BLU Studio 5.5 Motherboard Replacement: stap 7, afbeelding 1 van 3 BLU Studio 5.5 Motherboard Replacement: stap 7, afbeelding 2 van 3 BLU Studio 5.5 Motherboard Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Anti-Static Wrist Strap
    $7.95
    Koop
    • Use tweezers to carefully grasp and unhook all 7 flex cable connectors.
    • With the same tweezers, pry off the cable clasp that connects the motherboard to the sub PCBA.
    • Once the motherboard is disconnected from all components, use the tweezers or your fingers to remove it from the phone assembly.
    • Use the Anti-Static Wrist Strap to eliminate the possibility of introducing a static force that may damage the motherboard components.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Luis Gomez-Atehortua
452 Reputatie
4 handleidingen geschreven
USF Tampa, Team S1-G6, Nance Spring 2017 Lid van USF Tampa, Team S1-G6, Nance Spring 2017
USFT-NANCE-S17S1G6
3 Leden
8 handleidingen geschreven
Één opmerking
Can you do a BLU vivo XL4 Teardown?
Michael18751 - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 1,490
