Ga door naar hoofdinhoud
BLU Studio 5.0 S II Motherboard Replacement
Wat je nodig hebt
  1. BLU Studio 5.0 S II Motherboard Replacement, Remove back cover: stap 1, afbeelding 1 van 1
    • Remove the back cover of the phone with the plastic opening tool, or your fingers.
  2. BLU Studio 5.0 S II Motherboard Replacement, Remove battery: stap 2, afbeelding 1 van 1
    • Remove the battery from the phone with the plastic opening tool, or your fingers.
  3. BLU Studio 5.0 S II Motherboard Replacement, Motherboard: stap 3, afbeelding 1 van 2 BLU Studio 5.0 S II Motherboard Replacement, Motherboard: stap 3, afbeelding 2 van 2
    • Remove the microSD and SIM card. Gently tug on the microSD and SIM card to slide them out of their insert.
  4. BLU Studio 5.0 S II Motherboard Replacement: stap 4, afbeelding 1 van 2 BLU Studio 5.0 S II Motherboard Replacement: stap 4, afbeelding 2 van 2
    • Locate the 5 black 3.5mm screws and the 1 3.5mm silver screw on the top back plate.
    • Remove the 6 3.5mm screws by using a Phillips #00 screwdriver.
  5. BLU Studio 5.0 S II Motherboard Replacement: stap 5, afbeelding 1 van 2 BLU Studio 5.0 S II Motherboard Replacement: stap 5, afbeelding 2 van 2
    • Remove the inner top back black plate.
  6. BLU Studio 5.0 S II Motherboard Replacement: stap 6, afbeelding 1 van 2 BLU Studio 5.0 S II Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Locate the 2 black 3.5mm screws on the motherboard.
    • Remove the black 3.5 mm screws using a Phillips #00 screwdriver.
  7. BLU Studio 5.0 S II Motherboard Replacement: stap 7, afbeelding 1 van 3 BLU Studio 5.0 S II Motherboard Replacement: stap 7, afbeelding 2 van 3 BLU Studio 5.0 S II Motherboard Replacement: stap 7, afbeelding 3 van 3
    Gereedschap gebruikt in deze stap:
    Koop
    • Locate the 2 orange ribbons on opposite sides.
    • Carefully remove the two ribbon cables using tweezers.
    • Gently rock the cable back and forth equally from both sides to not damage the pins.
  8. BLU Studio 5.0 S II Motherboard Replacement: stap 8, afbeelding 1 van 2 BLU Studio 5.0 S II Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Gently rock the plastic opening tool back and forth until the motherboard releases from the phone.
    • Adhesion, identified with red circles, bonds the motherboard to the chassis. This may require extra effort to lift off from back of phone.
  9. BLU Studio 5.0 S II Motherboard Replacement: stap 9, afbeelding 1 van 2 BLU Studio 5.0 S II Motherboard Replacement: stap 9, afbeelding 2 van 2
    • Follow the wire from the motherboard.
    • Remove the black lining covering the wire.
  10. BLU Studio 5.0 S II Motherboard Replacement: stap 10, afbeelding 1 van 2 BLU Studio 5.0 S II Motherboard Replacement: stap 10, afbeelding 2 van 2
    • Locate the 5 black screws on inner black lower plate.
  11. BLU Studio 5.0 S II Motherboard Replacement: stap 11, afbeelding 1 van 2 BLU Studio 5.0 S II Motherboard Replacement: stap 11, afbeelding 2 van 2
    • Remove the bottom inner back plate.
  12. BLU Studio 5.0 S II Motherboard Replacement: stap 12, afbeelding 1 van 2 BLU Studio 5.0 S II Motherboard Replacement: stap 12, afbeelding 2 van 2
    • Holding the cable with the removal tool, gently pull in the direction of the cable to remove the connector from its socket.
  13. BLU Studio 5.0 S II Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Remove the whole motherboard.
    • The Motherboard contains the headphone jack and the power button.
Conclusie
To reassemble your device, follow these instructions in reverse order with the new motherboard.
Één andere persoon heeft deze handleiding voltooid.
Aaron Isaacs
107 Reputatie
1 Handleiding geschreven
IUPUI, Team S2-G3, Harley Spring 2017 Lid van IUPUI, Team S2-G3, Harley Spring 2017
IUPUI-HARLEY-S17S2G3
4 Leden
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 12
Altijd: 478
