Inleiding
A faulty motherboard can render your smartphone inoperable. This guide demonstrates the steps required to replace the motherboard on a BLU Life XL smartphone.
Wat je nodig hebt
Turn the device off by holding down the power button for up to 5 seconds and then tapping the "Power off" button on the screen.
Remove the rear cover using your hands at the lip on the device back cover. No tools required.
Remove the battery by lifting the lower edge of the battery up first.
Remove the two 12x3mm screws using the Phillips #000 screwdriver.
Remove the ribbon cables.
Één andere persoon heeft deze handleiding voltooid.
Één opmerking
how i identified the components in this motherboard
