Inleiding
If the touch screen or haptic feedback isn't working, the screen may need to be replaced. This guide will explain how to remove and replace the screen of your BLU Life X8.
Wat je nodig hebt
Flip the phone over so that the screen is facing down.
Slide the opening tool between the micro-USB port and the back cover.
Use the opening tool to create a gap.
Use the Phillips #00 bit to undo the nine 1.5mm screws from the back of the device.
Use the plastic opening tool to pry off the plastic guard covering the daughterboard and USB port.
Één andere persoon heeft deze handleiding voltooid.
