Ga door naar hoofdinhoud
Inleiding
If the phone has trouble turning on or charging properly, the battery may need to be replaced. This guide will explain how to access, remove, and replace your BLU Life X8 battery.
Onderdelen
Geen onderdelen opgegeven.
  1. Flip the phone over so that the screen is facing down. Slide the opening tool between the micro-USB port and the back cover.
    • Flip the phone over so that the screen is facing down.
    • Slide the opening tool between the micro-USB port and the back cover.
    • Use the opening tool to create a gap.
  2. Use your thumb to pry off the back panel once the gap is large enough.
    • Use your thumb to pry off the back panel once the gap is large enough.
  3. Once the back panel is off, locate the indent at the bottom of the battery.
    • Once the back panel is off, locate the indent at the bottom of the battery.
    • Use your thumb to slip the battery out of the case.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Alexander Prasil
534 Reputatie
5 handleidingen geschreven
USF Tampa, Team S1-G2, Nance Fall 2017 Lid van USF Tampa, Team S1-G2, Nance Fall 2017
USFT-NANCE-F17S1G2
4 Leden
6 handleidingen geschreven
0 Opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 261
