Inleiding
In order to remove the bottom motherboard the battery will also have to be removed. Be aware that removing the battery will void the phone warranty. The bottom motherboard is attached to the phone with an adhesive that is simply lifted up.
Wat je nodig hebt
Remove the five 4 mm JIS J000 screws from bottom plate
Remove the bottom casing.
