Ga door naar hoofdinhoud
BLU Dash Music 4.0 Speaker Replacement
Wat je nodig hebt
  1. BLU Dash Music 4.0 Speaker Replacement, Remove the Back Cover: stap 1, afbeelding 1 van 1
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 Speaker Replacement, Remove the Battery: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 Speaker Replacement, Remove the Screws: stap 3, afbeelding 1 van 2 BLU Dash Music 4.0 Speaker Replacement, Remove the Screws: stap 3, afbeelding 2 van 2
    • Use a screwdriver to remove each of the four screws.
  4. BLU Dash Music 4.0 Speaker Replacement, Remove the Inner Cover: stap 4, afbeelding 1 van 2 BLU Dash Music 4.0 Speaker Replacement, Remove the Inner Cover: stap 4, afbeelding 2 van 2
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone to pry the covers apart.
  5. BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: stap 5, afbeelding 1 van 3 BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: stap 5, afbeelding 2 van 3 BLU Dash Music 4.0 Speaker Replacement, Remove the Speaker: stap 5, afbeelding 3 van 3
    • Locate the speaker
    • Wedge the plastic opening tool between the speaker and the circuit board. Gently pry the speaker off the circuit board.
    • Use a soldering iron to remove the two wires that connect the speaker to the circuit board.
  6. BLU Dash Music 4.0 Speaker Replacement, Place the New Speaker: stap 6, afbeelding 1 van 1
    • Use the soldering iron to connect the two wires, that are attached to the speaker, to the circuit board.
    • Place the new speaker onto the circuit board.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lioma Terrero Soto
525 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 Lid van UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G8
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 471
