Ga door naar hoofdinhoud
BLU Dash Music 4.0 Micro USB Port Replacement
Wat je nodig hebt
  1. BLU Dash Music 4.0 Micro USB Port Replacement, Remove Back Cover: stap 1, afbeelding 1 van 1
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 Micro USB Port Replacement, Remove Battery: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 Micro USB Port Replacement, Remove Screws: stap 3, afbeelding 1 van 2 BLU Dash Music 4.0 Micro USB Port Replacement, Remove Screws: stap 3, afbeelding 2 van 2
    • Use a screwdriver to remove each of the four screws.
  4. BLU Dash Music 4.0 Micro USB Port Replacement, Remove Inner Cover: stap 4, afbeelding 1 van 2 BLU Dash Music 4.0 Micro USB Port Replacement, Remove Inner Cover: stap 4, afbeelding 2 van 2
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone such that the two covers are pulled apart.
  5. BLU Dash Music 4.0 Micro USB Port Replacement, Remove Black Pad: stap 5, afbeelding 1 van 1
    • Insert the plastic opening tool between black pad and the circuit board. Then gently pry off the black pad.
    • This will make the connections of the charging port more accessible.
  6. BLU Dash Music 4.0 Micro USB Port Replacement, Remove Solder Connections: stap 6, afbeelding 1 van 3 BLU Dash Music 4.0 Micro USB Port Replacement, Remove Solder Connections: stap 6, afbeelding 2 van 3 BLU Dash Music 4.0 Micro USB Port Replacement, Remove Solder Connections: stap 6, afbeelding 3 van 3
    • Using a soldering iron and a pair of pliers, melt the four soldering connections around the charging port.
    • Quickly pull off the current charging port while the soldering connections are still soft.
  7. BLU Dash Music 4.0 Micro USB Port Replacement, Mount New Charging Port: stap 7, afbeelding 1 van 1
    • Mount the new charging port so that the four prongs of the charging port line up with the four soldering connections.
    • Using a soldering iron, solder the connections in place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Lioma Terrero Soto
525 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 Lid van UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G8
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 854
