Ga door naar hoofdinhoud
BLU Dash Music 4.0 Headphone Jack Replacement
Wat je nodig hebt
  1. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Back Cover: stap 1, afbeelding 1 van 1
    • Use the plastic opening tool or your fingernail to pry off the back cover.
  2. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Battery: stap 2, afbeelding 1 van 1
    • Use the plastic opening tool or your fingernail to pry off the battery from the top right corner.
  3. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Screws: stap 3, afbeelding 1 van 2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Screws: stap 3, afbeelding 2 van 2
    • Use a screwdriver to remove each of the four screws.
  4. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Inner Cover: stap 4, afbeelding 1 van 2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Inner Cover: stap 4, afbeelding 2 van 2
    • Take the plastic opening tool and insert it in the crease between the front screen and the inner back cover.
    • Slide the plastic opening tool along the edge of the phone to pry the two covers apart.
  5. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Black Pad: stap 5, afbeelding 1 van 2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Black Pad: stap 5, afbeelding 2 van 2
    • Insert the plastic opening tool between the black pad and the circuit board. Then gently pry off the black pad.
    • This will make the connections of the charging port more accessible.
  6. BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Solder Connections: stap 6, afbeelding 1 van 2 BLU Dash Music 4.0 Headphone Jack Replacement, Remove the Solder Connections: stap 6, afbeelding 2 van 2
    • Using a soldering iron and a pair of pliers, melt the soldering connections around the headphone jack.
    • Quickly pull off the current headphone jack while the soldering connections are still soft.
  7. BLU Dash Music 4.0 Headphone Jack Replacement, Mount the New Headphone Jack: stap 7, afbeelding 1 van 1
    • Mount the new headphone jack such that the prongs of the headphone jack line up with the soldering connections.
    • Using a soldering iron, solder the connections in place.
Conclusie
Lioma Terrero Soto
525 Reputatie
5 handleidingen geschreven
UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014 Lid van UMass Dartmouth, Team 6-8, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G8
4 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 12
Altijd: 413
