Ga door naar hoofdinhoud
BLU Advance 4.0 Screen Replacement
Wat je nodig hebt
  1. BLU Advance 4.0 Screen Replacement, Removing the back cover: stap 1, afbeelding 1 van 2 BLU Advance 4.0 Screen Replacement, Removing the back cover: stap 1, afbeelding 2 van 2
    • With the back camera on the top side and facing you, find a notch on the bottom right side of the phone.
    • Unclip the cover by raising it up from the notch and sliding a flat rigid tool along the edge.
    Vraag FixBot
  2. BLU Advance 4.0 Screen Replacement, Revealing the motherboard: stap 2, afbeelding 1 van 3 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: stap 2, afbeelding 2 van 3 BLU Advance 4.0 Screen Replacement, Revealing the motherboard: stap 2, afbeelding 3 van 3
    • Remove the battery.
    • Remove 3 screws from each side with a Phillips 00 screwdriver.
    • Unclip the screen by sliding a flat rigid tool between the black and the blue side-band.
    • Pop off the blue side-band to be exposed to the motherboard.
    Vraag FixBot
  3. BLU Advance 4.0 Screen Replacement, Separating motherboard from screen: stap 3, afbeelding 1 van 1
    • Remove 2 black plastic buttons from each side, exposing metallic padding.
    • Gently pry the metallic padding off the motherboard with a flat rigid tool.
    • Carefully separate the clip-on tabs while lifting the motherboard away from the screen.
    • Forcefully separating the motherboard from the screen can further damage your device.
    Vraag FixBot
  4. BLU Advance 4.0 Screen Replacement, Screen: stap 4, afbeelding 1 van 2 BLU Advance 4.0 Screen Replacement, Screen: stap 4, afbeelding 2 van 2
    • The screen connector is located near the back camera and charger port.
    • Remove the attached screen by gently tugging the cord that connects it to main frame.
    • Pull gently to avoid damaging the connected cable.
    Vraag FixBot
  5. BLU Advance 4.0 Screen Replacement: stap 5, afbeelding 1 van 2 BLU Advance 4.0 Screen Replacement: stap 5, afbeelding 2 van 2
    • After screen removal, you should be left with the old screen and a plug-in tab .
    • Leave the motherboard and inner screen in one piece.
    • If the inner screen is cracked, replacing the outer screen is useless.
    Vraag FixBot
  6. BLU Advance 4.0 Screen Replacement, Placing in new screen: stap 6, afbeelding 1 van 1
    • Work backwards by carefully sliding in the new screen's plug-in tab into the screen connector.
    • The phone will not have sensitivity if the plug-in tab is damaged.
    Vraag FixBot
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Jon Sclar
292 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014 Lid van UMass Dartmouth, Team 6-2, Vijaybhaskar Fall 2014
UMASSD-VIJAYBHASKAR-F14S6G2
3 Leden
6 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 70
Altijd: 4,307
