Ga door naar hoofdinhoud
BEM Mojo 2 Speaker Replacement
Wat je nodig hebt
  1. BEM Mojo 2 Speaker Replacement, Speaker Battery: stap 1, afbeelding 1 van 1
    • Pull back the rubber corners to uncover the bottom screws.
    • Continue this process for all four 10 mm screws.
  2. BEM Mojo 2 Speaker Replacement: stap 2, afbeelding 1 van 1
    • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
  3. BEM Mojo 2 Speaker Replacement: stap 3, afbeelding 1 van 1
    • Remove the bottom cover of the speaker.
    • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
    • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
    • Caution: Be careful not to damage the chip.
  4. BEM Mojo 2 Speaker Replacement: stap 4, afbeelding 1 van 1
    • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
  5. BEM Mojo 2 Speaker Replacement: stap 5, afbeelding 1 van 1
    • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
  6. BEM Mojo 2 Speaker Replacement, Speaker Motherboard: stap 6, afbeelding 1 van 1
    • Use the J0 screwdriver to remove all four 10mm screws from the motherboard.
  7. BEM Mojo 2 Speaker Replacement: stap 7, afbeelding 1 van 1
    • Remove the red/black wires in addition to the blue/white wires using the tweezers.
  8. BEM Mojo 2 Speaker Replacement: stap 8, afbeelding 1 van 1
    • Remove bus wire from the speaker's motherboard and lift the motherboard out of the speaker.
  9. BEM Mojo 2 Speaker Replacement, Speaker: stap 9, afbeelding 1 van 1
    • Remove any glue that is left over from previous parts that may be covering the screw holes or the speakers drive.
  10. BEM Mojo 2 Speaker Replacement: stap 10, afbeelding 1 van 2 BEM Mojo 2 Speaker Replacement: stap 10, afbeelding 2 van 2
    • Remove the speaker's four 10 mm base screws.
  11. BEM Mojo 2 Speaker Replacement: stap 11, afbeelding 1 van 2 BEM Mojo 2 Speaker Replacement: stap 11, afbeelding 2 van 2
    • Pry out the speaker's base using the metal Spuger. Use caution upon this step, it will require the use of force.
    • Remove the wire that will be placed in the speakers driver hole for access to the speaker.
  12. BEM Mojo 2 Speaker Replacement: stap 12, afbeelding 1 van 2 BEM Mojo 2 Speaker Replacement: stap 12, afbeelding 2 van 2
    • Remove the speaker's two 10 mm screws that are located in its base then take the driver out of the speaker.
Conclusie
Rachel Iacoboni
618 Reputatie
5 handleidingen geschreven
Baylor, Team S1-G1, Johnson Spring 2018 Lid van Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 11
Altijd: 355
