Ga door naar hoofdinhoud
BEM Mojo 2 Speaker Motherboard Replacement
Wat je nodig hebt
  1. BEM Mojo 2 Speaker Motherboard Replacement, Speaker Battery: stap 1, afbeelding 1 van 1
    • Pull back the rubber corners to uncover the bottom screws.
    • Continue this process for all four 10 mm screws.
  2. BEM Mojo 2 Speaker Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Use the J0 screwdriver to remove all four 10mm screws from the bottom of the speaker.
    • Caution: It is important when using the screwdriver to not use excessive force as this may strip the screw and can damage the speaker itself.
  3. BEM Mojo 2 Speaker Motherboard Replacement: stap 3, afbeelding 1 van 1
    • Remove the bottom cover of the speaker.
    • Caution: Be careful when removing the bottom cover of the speaker as there are wires that connect to the speaker itself that become exposed upon base removal.
    • Remove all of the wires from the speakers internal chip, utilizing the tweezers.
    • Caution: Be careful not to damage the chip.
  4. BEM Mojo 2 Speaker Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Remove the speakers battery from its metal base, utilizing the plastic opening tool.
  5. BEM Mojo 2 Speaker Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Remove the wires from the speakers battery using the tweezers or by gently removing them by lightly pinching.
  6. BEM Mojo 2 Speaker Motherboard Replacement, Speaker Motherboard: stap 6, afbeelding 1 van 1
    • Use the J0 screwdriver to remove all four 10mm screws from the motherboard.
  7. BEM Mojo 2 Speaker Motherboard Replacement: stap 7, afbeelding 1 van 1
    • Remove the red/black wires in addition to the blue/white wires using the tweezers.
  8. BEM Mojo 2 Speaker Motherboard Replacement: stap 8, afbeelding 1 van 1
    • Remove bus wire from the speaker's motherboard and lift the motherboard out of the speaker.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Rachel Iacoboni
618 Reputatie
5 handleidingen geschreven
Baylor, Team S1-G1, Johnson Spring 2018 Lid van Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 5
Altijd: 265
