Ga door naar hoofdinhoud
BEM Mojo 2 Charging Base Motherboard Replacement
Wat je nodig hebt
  1. BEM Mojo 2 Charging Base Motherboard Replacement, Charging Base Battery: stap 1, afbeelding 1 van 1
    • Use the metal spudger to peel back the rubber from the bottom of the auxiliary charging base to reveal the screw.
  2. BEM Mojo 2 Charging Base Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Use the screwdriver with the J0 bit attatched to detach all four 10 mm screws from the charging base.
  3. BEM Mojo 2 Charging Base Motherboard Replacement: stap 3, afbeelding 1 van 2 BEM Mojo 2 Charging Base Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Pull the top cover off of the charging base to reveal the internal chip.
    • Use the plastic opening tool to pry the battery from the top cover.
    • Caution: Be careful when detaching battery from top cover as to not damage any of the wires attached to it.
  4. BEM Mojo 2 Charging Base Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Use the tweezers to carefully detach the wires from the internal chip.
    • Caution: Be careful to not damage the internal chip when removing the wires.
  5. BEM Mojo 2 Charging Base Motherboard Replacement, Charging Base Motherboard: stap 5, afbeelding 1 van 1
    • Use the tweezers to remove the red wire attached to the motherboard.
  6. BEM Mojo 2 Charging Base Motherboard Replacement: stap 6, afbeelding 1 van 1
    • Use the plastic opening tool to carefully lift and remove the motherboard from the charging base.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Rachel Iacoboni
618 Reputatie
5 handleidingen geschreven
Baylor, Team S1-G1, Johnson Spring 2018 Lid van Baylor, Team S1-G1, Johnson Spring 2018
BU-JOHNSON-S18S1G1
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 6
Altijd: 166
