Ga door naar hoofdinhoud
BELLA TXG-DS14 Heating Plate Replacement
Wat je nodig hebt
  1. BELLA TXG-DS14 Heating Plate Replacement, Heating Plate: stap 1, afbeelding 1 van 2 BELLA TXG-DS14 Heating Plate Replacement, Heating Plate: stap 1, afbeelding 2 van 2
    • Turn the device off and make sure it is cooled down. Then place the device in front of you and take the drawer out by placing a hand on the handle and pull towards you. Make sure the plug is out of the way before starting any of the following steps.
    • Slide the clear lock away from the button and press down on the release button to release the basket from the drawer.
  2. BELLA TXG-DS14 Heating Plate Replacement: stap 2, afbeelding 1 van 2 BELLA TXG-DS14 Heating Plate Replacement: stap 2, afbeelding 2 van 2
    • Turn the device onto its side and have the bottom surface face you.
    • Remove the 1.5 mm Phillips #1 screws from the bottom of the device. Rotate the screws counterclockwise with a Phillip's #1 screwdriver.
    • There should be 8 screws removed by the end of this step
    • Make sure to keep the screws in a safe spot
  3. BELLA TXG-DS14 Heating Plate Replacement: stap 3, afbeelding 1 van 3 BELLA TXG-DS14 Heating Plate Replacement: stap 3, afbeelding 2 van 3 BELLA TXG-DS14 Heating Plate Replacement: stap 3, afbeelding 3 van 3
    • Place the unscrewed bottom cover next to the device without damaging the cords by extending them.
    • Unscrew all the 1.2mm Phillip's #1 screw around the silver plate by rotating them counterclockwise with Phillip's #1 screwdriver to take the plate off.
    • There should be 6 screws removed by the end of this device
  4. BELLA TXG-DS14 Heating Plate Replacement: stap 4, afbeelding 1 van 2 BELLA TXG-DS14 Heating Plate Replacement: stap 4, afbeelding 2 van 2
    • Locate 8 silver holds that holds the silver plate and black cover together.
    • Use a 0.1mm Flathead screwdriver to bend the 8 silver folds toward the center of the circle to release the silver plate.
    • Be careful to not cut yourself on the sharp edges of the silver folds.
  5. BELLA TXG-DS14 Heating Plate Replacement: stap 5, afbeelding 1 van 1
    • Remove the silver heating plate and install the new one.
    • Fold the silver edges back into place and put the screws back in. For further reassembly , follow this guide in reverse order.
    • When installing the new silver heating plate, make sure to not over bend the silver edges as they can easily break.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Norma Velarde
130 Reputatie
1 Handleiding geschreven
UC Davis, Team S7-G6, Lore Fall 2018 Lid van UC Davis, Team S7-G6, Lore Fall 2018
UCD-LORE-F18S7G6
3 Leden
2 handleidingen geschreven
Één opmerking
Bella 1.6 txg-af15a
Basket and Drawers
Reinaldo Figueroa - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 26
Altijd: 1,825
