Ga door naar hoofdinhoud
B. Front Panel
Wat je nodig hebt
  1. B. Front Panel, Front Panel Assembly: stap 1, afbeelding 1 van 2 B. Front Panel, Front Panel Assembly: stap 1, afbeelding 2 van 2
    • Start by placing the NeoPixel rings into the circles. Make sure the pins are at the top center.
    • Thread the Inner Fan part into the circle.
    • Thread the tip into the Inner Fan.
    Vraag FixBot
    Voeg opmerking toe
  2. B. Front Panel, Front Panel Assembly: stap 2, afbeelding 1 van 2 B. Front Panel, Front Panel Assembly: stap 2, afbeelding 2 van 2
    • Screw the assembled Circle parts into the Front Face using 12x M3x8 countersunk screws
    Vraag FixBot
    Voeg opmerking toe
  3. B. Front Panel, Front Panel Assembly: stap 3, afbeelding 1 van 3 B. Front Panel, Front Panel Assembly: stap 3, afbeelding 2 van 3 B. Front Panel, Front Panel Assembly: stap 3, afbeelding 3 van 3
    • Glue the letters into the Middle Name Plate
    • Slide in the Middle Name Plate, Left and Right Nets into the Assembled Front Panel
    • Using 2x M3x8 button head screws secure the Middle Name Plate to the Assembled Front Panel.
    Vraag FixBot
    Voeg opmerking toe
  4. B. Front Panel, Front Panel Assembly: stap 4, afbeelding 1 van 1
    • Slide in the Left and Right Grill into the Front Panel Assembly
    Vraag FixBot
    Voeg opmerking toe
  5. B. Front Panel, Front Panel Mounting: stap 5, afbeelding 1 van 2 B. Front Panel, Front Panel Mounting: stap 5, afbeelding 2 van 2
    • The Front Panel mounts to the Frame with 4x M3x8 socket head/button head screws with 4x M3 T-Nuts and 2x M5x10 button head screws with 2 M5 T-Nuts
    • The Left and Right Lower Front Grill mount to the frame of the printer with 4x M3x8 button head screws with 4x M3 T-Nuts
    Vraag FixBot
    Voeg opmerking toe
  6. B. Front Panel, LCD: stap 6, afbeelding 1 van 3 B. Front Panel, LCD: stap 6, afbeelding 2 van 3 B. Front Panel, LCD: stap 6, afbeelding 3 van 3
    • Mount the backplate to the arm with 2x M3x8 button head screws.
    • Mount the ball to the arm with 1x M3x8 socket head screw.
    • I also used a drop of superglue.
    • Insert the PanelDue into the backplate lining up the screw holes. Screw the backplate to the front plate with 4x M3x10 button head screws.
    • Mount the full assembly to the front frame re-enforcement with 2x M5x10 button head screws and 2x M5 T-nuts
    Vraag FixBot
    Voeg opmerking toe
  7. B. Front Panel, Results: stap 7, afbeelding 1 van 2 B. Front Panel, Results: stap 7, afbeelding 2 van 2
    • Looks pretty cool huh?
    Vraag FixBot
    Voeg opmerking toe
Eindstreep
4 andere personen hebben deze handleiding voltooid.
David Husolo
9.382 Reputatie
33 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 33
Altijd: 1,645
