Ga door naar hoofdinhoud
Azpen A909 Front and Rear Facing Camera Assembly Replacement
Wat je nodig hebt
  1. Azpen A909 Front and Rear Facing Camera Assembly Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Begin by unscrewing the two 1.4 mm diameter Phillips #00 head screws at the top of the device.
  2. Azpen A909 Front and Rear Facing Camera Assembly Replacement: stap 2, afbeelding 1 van 1
    • Next, gently pry the cover off with a plastic opening tool or a similar instrument by loosening all of the anchoring points. Two of the anchoring points are circled in the image. Avoid excessive bending or pivoting, since doing so may break the anchoring points.
  3. Azpen A909 Front and Rear Facing Camera Assembly Replacement: stap 3, afbeelding 1 van 1
    • After prying open all of the anchoring points, the cover will lift off of the tablet.
    • To replace the cover, simply snap it back in place and re-insert the two screws. Because the speaker is not fully fixed to the interior of the tablet, make sure that it is in the position that will allow it to fit inside the speaker mounting on the cover.
  4. Azpen A909 Front and Rear Facing Camera Assembly Replacement, Front and Rear Facing Camera Assembly: stap 4, afbeelding 1 van 1
    • Using a plastic opening tool, gently peel back the black electrical tape to reveal the power strip and the front facing camera, which is marked by the red box in the image.
  5. Azpen A909 Front and Rear Facing Camera Assembly Replacement: stap 5, afbeelding 1 van 1
    • Gently pull the front facing camera out of its mounting point. Use a spudger if necessary.
  6. Azpen A909 Front and Rear Facing Camera Assembly Replacement: stap 6, afbeelding 1 van 1
    • Using the spudger, pry the rear facing camera its power strip off the circuit board. This may require some force, since a strong adhesive is used to mount the camera assembly to that point.
  7. Azpen A909 Front and Rear Facing Camera Assembly Replacement: stap 7, afbeelding 1 van 1
    • Lift open the connector flap with the spudger.
  8. Azpen A909 Front and Rear Facing Camera Assembly Replacement: stap 8, afbeelding 1 van 1
    • At this point, all points of the camera assembly should be detached from the device.
    • Lift and remove the power strip/camera assembly from the device with a pair of tweezers.
Conclusie
Jordan
381 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 3-5, Duarte Spring 2015 Lid van UMass Dartmouth, Team 3-5, Duarte Spring 2015
UMASSD-DUARTE-S15S3G5
3 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 190
