Inleiding
The internal Wi-Fi antenna is important for connecting your tablet to Wi-Fi internet. Replacing the Azpen A720 Wi-Fi antenna is relatively simple. If you are having issues connecting to Wi-Fi use this guide to replace you internal Wi-Fi antenna.
Wat je nodig hebt
Use a Phillips #00 screwdriver to remove the two 4mm screws found on the top edge of the tablet near the power button.
Locate the gray cord attached to the motherboard and the battery. This is the wifi antenna.
