Ga door naar hoofdinhoud
Azpen A701 Screen Replacement
Wat je nodig hebt
  1. Azpen A701 Screen Replacement, General Disassembly Prerequisite Guide: stap 1, afbeelding 1 van 1
    • Remove the two 2cm screws on the bottom using the PH0 Phillips head screw driver.
  2. Azpen A701 Screen Replacement: stap 2, afbeelding 1 van 2 Azpen A701 Screen Replacement: stap 2, afbeelding 2 van 2
    • Pry open the back piece with the plastic spudger.
    • Remove the back piece from the device.
    • The back panel may be difficult to pry off, use gentle force.
  3. Azpen A701 Screen Replacement: stap 3, afbeelding 1 van 1
    • Disconnect speaker (which is attached by black and red wires) from back piece using plastic spudger.
  4. Azpen A701 Screen Replacement: stap 4, afbeelding 1 van 1
    • Gently pry the battery off of the device with the plastic spudger.
    • There is a large amount of glue holding the battery to the device.
    • Do not puncture the battery with the plastic spudger.
  5. Azpen A701 Screen Replacement, Screen: stap 5, afbeelding 1 van 3 Azpen A701 Screen Replacement, Screen: stap 5, afbeelding 2 van 3 Azpen A701 Screen Replacement, Screen: stap 5, afbeelding 3 van 3
    • Disconnect the two largest (of the three) ZIF cables by prying open the flap with a plastic spudger to gently remove them.
  6. Azpen A701 Screen Replacement: stap 6, afbeelding 1 van 1
    • Peel off the black tape from the corner of the motherboard (indicated by the blue surface of the device).
  7. Azpen A701 Screen Replacement: stap 7, afbeelding 1 van 3 Azpen A701 Screen Replacement: stap 7, afbeelding 2 van 3 Azpen A701 Screen Replacement: stap 7, afbeelding 3 van 3
    • Use a PH000 Phillips head screw driver to remove the three screws that connect the motherboard to the front panel.
    • When removing the motherboard, be cautious of the gray wire connected from the motherboard to the actual device.
  8. Azpen A701 Screen Replacement: stap 8, afbeelding 1 van 1
    • Remove the motherboard and the battery and set aside.
  9. Azpen A701 Screen Replacement: stap 9, afbeelding 1 van 3 Azpen A701 Screen Replacement: stap 9, afbeelding 2 van 3 Azpen A701 Screen Replacement: stap 9, afbeelding 3 van 3
    • Remove the small orange tape attached with a gray wire from the top corner of the device. This is the antenna.
    • Use a plastic spudger around the silver lining within the device to pry the screen off.
    • The metal screen assembly is two pieces. When removing the screen, make sure to pry off both pieces at once.
  10. Azpen A701 Screen Replacement: stap 10, afbeelding 1 van 1
    • Replace the broken screen and reverse the steps to re-assemble the device.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Michael
568 Reputatie
4 handleidingen geschreven
Colorado Springs, Team 2-1, Panko Spring 2015 Lid van Colorado Springs, Team 2-1, Panko Spring 2015
UCCS-PANKO-S15S2G1
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 700
