Ga door naar hoofdinhoud
Axess TA2513-10WT Side Button Replacement
Wat je nodig hebt
  1. Axess TA2513-10WT Side Button Replacement, Back Cover: stap 1, afbeelding 1 van 1
    • Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
  2. Axess TA2513-10WT Side Button Replacement: stap 2, afbeelding 1 van 3 Axess TA2513-10WT Side Button Replacement: stap 2, afbeelding 2 van 3 Axess TA2513-10WT Side Button Replacement: stap 2, afbeelding 3 van 3
    • Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
    • Slide the plastic opening tool gently along the sides.
    • If a small gap is not created between the screen and the back cover, pry gently upward at each of these latching points.
  3. Axess TA2513-10WT Side Button Replacement: stap 3, afbeelding 1 van 1
    • Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
  4. Axess TA2513-10WT Side Button Replacement: stap 4, afbeelding 1 van 1
    • Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
  5. Axess TA2513-10WT Side Button Replacement, Buttons: stap 5, afbeelding 1 van 2 Axess TA2513-10WT Side Button Replacement, Buttons: stap 5, afbeelding 2 van 2
    • Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
  6. Axess TA2513-10WT Side Button Replacement: stap 6, afbeelding 1 van 2 Axess TA2513-10WT Side Button Replacement: stap 6, afbeelding 2 van 2
    • Unlatch the clear rubber holder from the posts with the tweezers.
  7. Axess TA2513-10WT Side Button Replacement: stap 7, afbeelding 1 van 2 Axess TA2513-10WT Side Button Replacement: stap 7, afbeelding 2 van 2
    • With tweezers, pull the rubber holder from the back cover completely.
  8. Axess TA2513-10WT Side Button Replacement: stap 8, afbeelding 1 van 3 Axess TA2513-10WT Side Button Replacement: stap 8, afbeelding 2 van 3 Axess TA2513-10WT Side Button Replacement: stap 8, afbeelding 3 van 3
    • Remove the individual buttons with tweezers.
Conclusie
Lori Scott
101 Reputatie
1 Handleiding geschreven
Baylor, Team 6-3, Shaver Spring 2015 Lid van Baylor, Team 6-3, Shaver Spring 2015
BU-SHAVER-S15S6G3
3 Leden
10 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 219
