Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Lay the tablet down on a flat surface with the screen facing up, and the external camera facing upwards and closest to you.
Insert the plastic opening tool in the space between the screen and the back cover above the volume buttons.
Slide the plastic opening tool gently along the sides.
Place the spudger in an open space to keep the back case from shutting while you continue to slide the opening tool.
Remove the back cover with your hands once all points have been unlatched. It should separate completely from the screen that contains the battery and chip components.
Orient the tablet's back cover so that the inside faces up and the buttons are positioned at the top left corner.
Gereedschap gebruikt in deze stap:Tweezers$4.99-
Unlatch the clear rubber holder from the posts with the tweezers.
With tweezers, pull the rubber holder from the back cover completely.
