Ga door naar hoofdinhoud
Axe Empire 2.0 OLED Board Replacement
Wat je nodig hebt
  1. Axe Empire 2.0 OLED Board Replacement, OLED Board: stap 1, afbeelding 1 van 2 Axe Empire 2.0 OLED Board Replacement, OLED Board: stap 1, afbeelding 2 van 2
    • Use an Allen key to remove four total screws.
    • 2.5 mm screws.
    • 1.2 mm screw.
  2. Axe Empire 2.0 OLED Board Replacement: stap 2, afbeelding 1 van 3 Axe Empire 2.0 OLED Board Replacement: stap 2, afbeelding 2 van 3 Axe Empire 2.0 OLED Board Replacement: stap 2, afbeelding 3 van 3
    • Press and hold the release button while lightly pulling the spring bolt out.
    • If the spring bolt has not been serviced with lube after a long time you might need to pull harder. This is a great time to lube the spring bolt.
  3. Axe Empire 2.0 OLED Board Replacement: stap 3, afbeelding 1 van 3 Axe Empire 2.0 OLED Board Replacement: stap 3, afbeelding 2 van 3 Axe Empire 2.0 OLED Board Replacement: stap 3, afbeelding 3 van 3
    • Remove the two main screws using a 2.5 mm Allen key to separate the air transfer plate from the frame.
  4. Axe Empire 2.0 OLED Board Replacement: stap 4, afbeelding 1 van 2 Axe Empire 2.0 OLED Board Replacement: stap 4, afbeelding 2 van 2
    • Remove the screw using a 2.5 mm Allen key and remove the foregrip from the frame.
  5. Axe Empire 2.0 OLED Board Replacement: stap 5, afbeelding 1 van 2 Axe Empire 2.0 OLED Board Replacement: stap 5, afbeelding 2 van 2
    • Use a 1.2 mm Allen key to remove the screw, and remove the cover to expose the OLED Board.
  6. Axe Empire 2.0 OLED Board Replacement: stap 6, afbeelding 1 van 3 Axe Empire 2.0 OLED Board Replacement: stap 6, afbeelding 2 van 3 Axe Empire 2.0 OLED Board Replacement: stap 6, afbeelding 3 van 3
    • Remove the last screw with a 2.5 mm Allen key to loosen the OLED Board.
    • Use a pick tool to carefully remove the battery and OLED Board together out of the foregrip.
    • Wear gloves in case battery is defective and leaking acid.
  7. Axe Empire 2.0 OLED Board Replacement: stap 7, afbeelding 1 van 2 Axe Empire 2.0 OLED Board Replacement: stap 7, afbeelding 2 van 2
    • Disconnect the battery from the OLED board.
Conclusie
Christopher Ramos
345 Reputatie
1 Handleiding geschreven
CSU Los Angeles, Team 11-2, Grodsky Fall 2021 Lid van CSU Los Angeles, Team 11-2, Grodsky Fall 2021
CSULA-GRODSKY-F21S11G2
1 Lid
1 handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 9
Altijd: 196
