Inleiding
This guide will walk you through the necessary steps in order to replace the actual 4MP (mega pixel) camera for the AvertX HD810. Both the 'Clear Dome Cover' and the 'IR LED Light Board' guides are required prerequisites for this guide. You will need a PH1, PH0, and PH000 (Phillips Head) screwdrivers to complete this guide. It's important to have the camera turned off and unplugged from any power source for this procedure.
Wat je nodig hebt
Lift off the paintable snap-on cover from the AvertX HD810 dome security camera.
Use the PH1 screwdriver to remove or loosen both 10mm screws on either side of the inner protective lens cover. This will loosen both the cover and the IR LED lightboard.
Using a PH1 screwdriver, remove the two 8mm screws holding the plastic base to the metal base of the camera.
