Ga door naar hoofdinhoud
Autosampler Programming (For Old & New Versions)
Wat je nodig hebt
  1. Autosampler Programming  (For Old & New Versions), Turn on battery and autosampler: stap 1, afbeelding 1 van 2 Autosampler Programming  (For Old & New Versions), Turn on battery and autosampler: stap 1, afbeelding 2 van 2
    • 1. Switch battery "ON".
    • 2. Autosampler: Push "ON" button.
    • It will say ...STANDBY...
  2. Autosampler Programming  (For Old & New Versions), Select Program Mode: stap 2, afbeelding 1 van 2 Autosampler Programming  (For Old & New Versions), Select Program Mode: stap 2, afbeelding 2 van 2
    • 3. Push "ENTER/PROGRAM" button to see the "[PROGRAM, CONFIGURE] SAMPLER" screen. Push “ENTER/PROGRAM” button to select "PROGRAM".
    • 4. This will bring up the "[TIME, FLOW] PACED SAMPLING" screen. Use arrow to select "FLOW" then push “ENTER/PROGRAM” button.
  3. Autosampler Programming  (For Old & New Versions), Set Number, Type, and Size of Samples: stap 3, afbeelding 1 van 3 Autosampler Programming  (For Old & New Versions), Set Number, Type, and Size of Samples: stap 3, afbeelding 2 van 3 Autosampler Programming  (For Old & New Versions), Set Number, Type, and Size of Samples: stap 3, afbeelding 3 van 3
    • 5. New screen shows: "SAMPLE EVERY __ PULSES." Press 20. Then push the “ENTER/PROGRAM” button.
    • 6. New screen will read: "MULTIPLEX SAMPLES?" Use arrow to select "NO". Then push the “ENTER/PROGRAM” button.
    • 7. New screen will read: "SAMPLE VOLUMES OF "____" ML". Press 1000. Then push the “ENTER/PROGRAM” button.
  4. Autosampler Programming  (For Old & New Versions), Starting Sampling: stap 4, afbeelding 1 van 3 Autosampler Programming  (For Old & New Versions), Starting Sampling: stap 4, afbeelding 2 van 3 Autosampler Programming  (For Old & New Versions), Starting Sampling: stap 4, afbeelding 3 van 3
    • 8. New screen will read: "ENTER START TIME?" Use arrow to select "NO". Then push the “ENTER/PROGRAM” button. New screen: "PROGRAMMING SEQUENCE COMPLETE...". Then screen will read: "PROGRAM HALTED".
    • 9. Push "START SAMPLING" button. Screen will read: "[START, RESUME] SAMPLING PROGRAM?" Push "ENTER/PROGRAM" button to "START". Then push "ENTER/PROGRAM" button again to "START SAMPLING AT BOTTLE 1".
    • 10. Then should see on screen: "START FLOW COUNT AT __:__" (time).
    • It will take some time before it starts sampling.
    • Eventually screen will show: " BOTTLE 1 AFTER 20 PULSES".
Eindstreep
Één andere persoon heeft deze handleiding voltooid.
Brooke Mason
2.928 Reputatie
17 handleidingen geschreven
Open-Storm Lid van Open-Storm
Community
14 Leden
24 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 164
