Ga door naar hoofdinhoud
Autosampler Battery Replacement & Voltage Check (For Old & New Versions)
Wat je nodig hebt
  1. Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Disconnect the batteries completely: stap 1, afbeelding 1 van 3 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Disconnect the batteries completely: stap 1, afbeelding 2 van 3 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Disconnect the batteries completely: stap 1, afbeelding 3 van 3
    • 1. Disconnect the plug to the solar panel (yellow circle).
    • Then, grabbing the green connector and pull the battery connector from the solar charge controller (blue arrow).
    • This will be done inside the node. It was removed from the node to make it easier to see for the tutorial.
    • 2. Disconnect the plugs for the autosampler battery.
    • 3. Disconnect the connector that plugs into the battery port of the sampler.
    • If disconnect battery before solar panel, this can damage the solar charger!
  2. Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Checking battery voltages: stap 2, afbeelding 1 van 3 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Checking battery voltages: stap 2, afbeelding 2 van 3 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Checking battery voltages: stap 2, afbeelding 3 van 3
    • 4. Make sure multimeter is measuring in DC current (red boxes).
    • Make sure multimeter is measuring in Volts (blue box).
    • 5. Check the voltage of the lead acid autosampler battery. Fully charged lead acid battery should be around 13-14 V.
    • Remember: Red to red and black to black!
    • 6. Check the voltage of the lithium ion node battery. Fully charged lithium ion battery should around 4 V.
  3. Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Reconnect the batteries: stap 3, afbeelding 1 van 3 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Reconnect the batteries: stap 3, afbeelding 2 van 3 Autosampler Battery Replacement & Voltage Check  (For Old & New Versions), Reconnect the batteries: stap 3, afbeelding 3 van 3
    • 7. First reconnect the autosampler battery (black box).
    • 8. Then reconnect lithium ion battery in the node (blue box).
    • Remember to plug in the other connector into the autosampler.
    • 9. Secure solar charge controller to the side of the enclosure using velcro (red box).
    • Then plug in the solar panel last (orange box).
Eindstreep
3 andere personen hebben deze handleiding voltooid.
Brooke Mason
2.928 Reputatie
17 handleidingen geschreven
Open-Storm Lid van Open-Storm
Community
14 Leden
24 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 150
