Ga door naar hoofdinhoud
Automatic Tommy 20 Ammo Drum Replacement
Wat je nodig hebt
  1. Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: stap 1, afbeelding 1 van 2 Automatic Tommy 20 Ammo Drum Replacement, Splitting the Gun into Two Halves: stap 1, afbeelding 2 van 2
    • Locate the orange slider on the front side of the gun.
    • Pull the orange slider towards the back of the gun while lifting up on the nose the gun.
  2. Automatic Tommy 20 Ammo Drum Replacement: stap 2, afbeelding 1 van 3 Automatic Tommy 20 Ammo Drum Replacement: stap 2, afbeelding 2 van 3 Automatic Tommy 20 Ammo Drum Replacement: stap 2, afbeelding 3 van 3
    • Remove the single 1/8 in. screw at the junction of the body and the nose using a Philips #00 Screwdriver.
    • Remove all parts within the chamber to be able to completely detach the nose of the gun.
    • Be careful to keep track of all the components for reassembly.
  3. Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: stap 3, afbeelding 1 van 3 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: stap 3, afbeelding 2 van 3 Automatic Tommy 20 Ammo Drum Replacement, Ammo Drum: stap 3, afbeelding 3 van 3
    • Remove the 1/16 in. screws using a Phillips #00 Screwdriver as indicated in the photo on the left.
    • Remove the 1 mm screw on the battery lid using a Philips #1 Screwdriver as indicated in the photo on the left.
  4. Automatic Tommy 20 Ammo Drum Replacement: stap 4, afbeelding 1 van 1
    • Carefully spread apart the two halves of the gun, and lift out the ammo drum.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Moira Foster
419 Reputatie
3 handleidingen geschreven
Cal Poly, Team 6-22, Maness Fall 2014 Lid van Cal Poly, Team 6-22, Maness Fall 2014
CPSU-MANESS-F14S6G22
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 794
