Ga door naar hoofdinhoud
Audiovox Tri-mode CDM-9000 Keypad Replacement
Wat je nodig hebt
  1. Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: stap 1, afbeelding 1 van 3 Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: stap 1, afbeelding 2 van 3 Audiovox Tri-mode CDM-9000 Keypad Replacement, Keypad: stap 1, afbeelding 3 van 3
    • Flip your phone over so the screen is facing down.
    • About half way down there is a small button with a few groves. Push this button in an upward fashion. This will release the battery from the back of the cell phone.
  2. Audiovox Tri-mode CDM-9000 Keypad Replacement: stap 2, afbeelding 1 van 3 Audiovox Tri-mode CDM-9000 Keypad Replacement: stap 2, afbeelding 2 van 3 Audiovox Tri-mode CDM-9000 Keypad Replacement: stap 2, afbeelding 3 van 3
    • Once the battery has been removed, you will need a small Phillips 60 mm screwdriver. Remove the two 1.2mm Phillips #1 screws on the back of the phone.
    • Use a spudger tool to pry apart the phone. It may be a little difficult to pry open. Use the flat part of the spudger tool and go all around the phone. It will come apart.
  3. Audiovox Tri-mode CDM-9000 Keypad Replacement: stap 3, afbeelding 1 van 3 Audiovox Tri-mode CDM-9000 Keypad Replacement: stap 3, afbeelding 2 van 3 Audiovox Tri-mode CDM-9000 Keypad Replacement: stap 3, afbeelding 3 van 3
    • Once you have the phone apart simply remove the key pad and replace it with the new one.
    • Don't forget to put the screws back in. Place the battery back on the phone.
    • Push the two parts of the phone back together. You will here a loud click when the phone is back together.
Conclusie
Summer Sines
406 Reputatie
3 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 13
Altijd: 257
