Deze versie kan foutieve bewerkingen bevatten. Schakel over naar de recentste gecontroleerde momentopname.
Wat je nodig hebt
Deze stap is niet vertaald. Help het te vertalen
Turn the device upside down.
Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
Remove the four screws from the base using a Phillips #1 screwdriver.
Turn the device right-side up.
Gently pull the top panel off of the device.
Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
Pull back the board gently to avoid disconnecting the attached wires.
Slide a plastic opening tool along the rim of the faulty speaker where it meets the plastic casing.
Using your thumb, applying constant pressure, pull back the plastic tab towards the speaker and away from the metal bracket.
Simultaneously insert a Phillips #00 screwdriver into the square hole on the underside of clock and push through to lift the metal bracket off of the plastic tab.
Repeat the second part of "Step 7" for the other hole.
Pull up on the metal brackets, found on either side, until the speaker is completely removed. Removing the speaker is rather challenging. Don't get discouraged if it takes multiple attempts!
3 andere personen hebben deze handleiding voltooid.
