Ga door naar hoofdinhoud
Audiovox CR8030iE5 Speakers Replacement
Wat je nodig hebt
  1. Audiovox CR8030iE5 Speakers Replacement, Top-Casing: stap 1, afbeelding 1 van 1
    • Turn the device upside down.
    • Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
  2. Audiovox CR8030iE5 Speakers Replacement: stap 2, afbeelding 1 van 1
    • Remove the four screws from the base using a Phillips #1 screwdriver.
  3. Audiovox CR8030iE5 Speakers Replacement: stap 3, afbeelding 1 van 1
    • Turn the device right-side up.
    • Gently pull the top panel off of the device.
  4. Audiovox CR8030iE5 Speakers Replacement: stap 4, afbeelding 1 van 1
    • Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
  5. Audiovox CR8030iE5 Speakers Replacement: stap 5, afbeelding 1 van 1
    • Pull back the board gently to avoid disconnecting the attached wires.
    • This allows you to view the soldered connections on the other side, and the internal components.
  6. Audiovox CR8030iE5 Speakers Replacement, Speakers: stap 6, afbeelding 1 van 1
    • Notice that there are two speakers located on opposite sides of the inside of your Audiovox.
    • Slide a plastic opening tool along the rim of the faulty speaker where it meets the plastic casing.
    • This action removes any glue or adhesive that holds the speaker to the wall of your Audiovox.
  7. Audiovox CR8030iE5 Speakers Replacement: stap 7, afbeelding 1 van 2 Audiovox CR8030iE5 Speakers Replacement: stap 7, afbeelding 2 van 2
    • Using your thumb, applying constant pressure, pull back the plastic tab towards the speaker and away from the metal bracket.
    • Simultaneously insert a Phillips #00 screwdriver into the square hole on the underside of clock and push through to lift the metal bracket off of the plastic tab.
  8. Audiovox CR8030iE5 Speakers Replacement: stap 8, afbeelding 1 van 1
    • Repeat the second part of "Step 7" for the other hole.
  9. Audiovox CR8030iE5 Speakers Replacement: stap 9, afbeelding 1 van 1
    • Pull up on the metal brackets, found on either side, until the speaker is completely removed. Removing the speaker is rather challenging. Don't get discouraged if it takes multiple attempts!
    • Each speaker contains a powerful magnet. Try to keep them away from nearby metal objects.
Conclusie
3 andere personen hebben deze handleiding voltooid.
Nab Sengupta
55 Reputatie
4 handleidingen geschreven
Cal Poly, Team 10-39, Amido Spring 2013 Lid van Cal Poly, Team 10-39, Amido Spring 2013
CPSU-AMIDO-S13S10G39
4 Leden
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 9
Altijd: 1,061
