Ga door naar hoofdinhoud
Deze handleiding heeft recentere wijzigingen. Schakel over naar de nieuwste niet-geverifieerde versie.
Audiovox CDM-8900 Logic Board Replacement
Wat je nodig hebt
  1. Audiovox CDM-8900 Logic Board Replacement, Battery: stap 1, afbeelding 1 van 2 Audiovox CDM-8900 Logic Board Replacement, Battery: stap 1, afbeelding 2 van 2
    • Hold the phone in one hand, slide the latch up, and pull the battery up to remove it.
  2. Audiovox CDM-8900 Logic Board Replacement, Antenna: stap 2, afbeelding 1 van 3 Audiovox CDM-8900 Logic Board Replacement, Antenna: stap 2, afbeelding 2 van 3 Audiovox CDM-8900 Logic Board Replacement, Antenna: stap 2, afbeelding 3 van 3
    • Grasp the antenna at its base and twist to unscrew.
    • Remove the antenna along with its plastic casing from inside the battery housing. Keep the antenna in the plastic casing for reassembly.
  3. Audiovox CDM-8900 Logic Board Replacement, Logic Board: stap 3, afbeelding 1 van 3 Audiovox CDM-8900 Logic Board Replacement, Logic Board: stap 3, afbeelding 2 van 3 Audiovox CDM-8900 Logic Board Replacement, Logic Board: stap 3, afbeelding 3 van 3
    • Remove the small rubber insert from the top of the phone to access the top screw.
    • Warning: Screws are very small and may be difficult to see while unscrewing.
    • Unscrew all five (5) screws on the back of cell phone.
    • If screws do not remove after fully unthreading, gently invert and tap phone in hand until the screws come loose.
  4. Audiovox CDM-8900 Logic Board Replacement: stap 4, afbeelding 1 van 3 Audiovox CDM-8900 Logic Board Replacement: stap 4, afbeelding 2 van 3 Audiovox CDM-8900 Logic Board Replacement: stap 4, afbeelding 3 van 3
    • Wedge back plate away from cell phone using the leverage from the plastic spudger.
    • The volume control button on the left side of the phone will be loose. Make sure to carefully reinsert during reassembly.
    • Detach logic board from LCD screen connector by gently detaching the small copper plate on the top right of the logic board (shown circled in blue and detached).
  5. Audiovox CDM-8900 Logic Board Replacement: stap 5, afbeelding 1 van 3 Audiovox CDM-8900 Logic Board Replacement: stap 5, afbeelding 2 van 3 Audiovox CDM-8900 Logic Board Replacement: stap 5, afbeelding 3 van 3
    • Pop the logic board out from the front of the cell phone.
    • Before reassembly, be sure keypad is lined up with logic board.
    • Before reassembly, be sure camera lens is properly aligned at the top of the logic board and volume controls are in place.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Aaron Shaw
159 Reputatie
6 handleidingen geschreven
Cal Poly, Team 28-31, Regan Spring 2010 Lid van Cal Poly, Team 28-31, Regan Spring 2010
CPSU-REGAN-S10S28G31
4 Leden
12 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 2,797
